Exposition Flop Avril 2022
- Travail du bois : Non
- Compétence en photographie : Non
- Compétence en couture : Non
- Impression 3D : Non
Re: Exposition Flop Avril 2022
Essai de la bibliothèque ultrasonic ...
A suivre
https://github.com/ErickSimoes/Ultrason ... Simple.ino
A suivre
Code source mis à jour le 29/03/2022
Code : Tout sélectionner
#include <AccelStepper.h>
#include <AsyncSonarLib.h>
#include <OneButton.h>
#define DEBUG 1
#define WITH_MOTOR 1
// level de log debug
#define LOG_DEBUG 1
#define LIGHT_VEILLE 2
#define LIGHT_VEILLE_BLINK 150
#define LIGHT_ACTIVATION 255
#define LIGHT_VEILLE2 80
#define LIGHT_RAZ 80
#define MOTOR_POS_VEILLE 3000//1200
#define MOTOR_REF_0 0
#define MOTOR_REF_MAX 3200
#define RETURN_TO_RAZ -3500
#define DELAY_RAZ 20000
#define DELAY_LIGHT_VEILLE 1500
#define DELAY_LIGHT_VEILLE2 5000
#define DELAY_LIGHT_ACTIVATION 5000
#define DELAY_GO_VEILLE2 20000
#define DELTA_MOVE_MIN 50
#define DELTA_MOVE_MAX 300
#define PIN_LAMP 11
#define PIN_STEP 8
#define PIN_DIR 4
#define PIN_UP A0
#define PIN_DOWN A1
#define PIN_SONAR A5
#define BANDGAP 10
// SPEED 500 ne fonctionne pas
#define MAXSPEED_WORKMDODE 400
#define MAXSPEED_TUNINGMODE 100
#define MOTOR_ACCELERATION 200
#define MAXSPEED_INIT_RAZ 200
struct slope
uint32_t startTime;
uint8_t startValue; // (0-255)
uint8_t stopValue; // (255-0)
uint16_t slopeDuration; // (1-65535)
int32_t currentValue;
struct variablesToSave
uint16_t stepToFloor;
byte dummy_1; // just for note
int dummy_2 = -8; // just for note
enum enumMotorState
INIT,
OFF,
UP,
DOWN,
enumMotorState motorState, previousMotorState;
boolean onEntryState;
int8_t sens;
slope lampSlope;
#ifdef DEBUG
uint32_t u32_cpu_load;
#endif
uint16_t toto, oldtoto, initMeasureRAZ, lastMeasureSensor;
unsigned long myTime, lastTimeStep;
variablesToSave eeprom;
enum enumOeuvreState
VEILLE = 0,
ACTIVATION, // dès qu'on met la main
VEILLE2,
RAZ // on recherche la position 0
enumOeuvreState oeuvreState, previousOeuvreState;
enum enumScenarState
INIT_SCENAR,
RUN
enumScenarState scenarState;
enum enumSONARState
INIT_SONAR,
STABLE
struct scenar
enumOeuvreState oeuvreState;
unsigned long timeValue; // valeur de temps utilisable pour contrôler ce que l'on veut
long positionMotor; // position du moteur demandée, on ne change pas tant qu'on n'y est pas
enumMotorState motorState;
scenar currentScenar;
enumSONARState sonarState;
unsigned long lastTSMesure=0;
/***** Prototype definition of code *****/
void slopeInit(slope *thisSlope, uint16_t startValue, uint16_t stopValue, uint16_t slopeDuration);
boolean slopeUpdate(slope *thisSlope);
void PingRecieved(AsyncSonar &sonar);
void TimeOut(AsyncSonar &sonar);
void changeLight(int value);
void changeMotor(long value);
void scenarVeille();
void scenarActivation();
void scenarVeille2();
void scenarRAZ();
AccelStepper stepper(AccelStepper::DRIVER, PIN_STEP, PIN_DIR);
// AccelStepper stepper(AccelStepper::FULL4WIRE, 2, 3, 4, 5);
AsyncSonar sonar(PIN_SONAR, PingRecieved, TimeOut);
OneButton buttonUp(PIN_UP, true, true); // active low, pull-up
OneButton buttonDown(PIN_DOWN, true, true); // active low, pull-up
int currentPosition_light;
long currentPosition_motor;
unsigned int absTmp(int v){
return (v>=0)?v:(-1*v);
void setup()
#ifdef DEBUG
Serial.begin(250000); // for debug purposes
#endif
// initialize lamp
pinMode(PIN_LAMP, OUTPUT);
analogWrite(PIN_LAMP, 0);
// initialize stepper;
stepper.setMaxSpeed(MAXSPEED_WORKMDODE);
stepper.setAcceleration(MOTOR_ACCELERATION);
// initialize sonar
sonar.Start(500);
sonarState = INIT_SONAR;
// initialize motor state machine
motorState = INIT;
previousMotorState = ~INIT;
myTime = millis();
//Serial.println("Before Delay setup");
//delay(10000);
//Serial.println("After Delay setup");
changeScenar(RAZ);
void loop()
myTime = millis();
switch (currentScenar.oeuvreState)
case VEILLE:
scenarVeille();
break;
case ACTIVATION:
scenarActivation();
break;
case VEILLE2:
scenarVeille2();
break;
case RAZ:
scenarRAZ();
break;
default:
break;
sonar.Update(&sonar);
stepper.run();
// delay(10);
// ----- button Up callback functions
// This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
void clickbuttonUp()
// stepper.move(10);
// analogWrite(PIN_LAMP, LIGHT_VEILLE);
// if(oeuvreState == VEILLE){
// oeuvreState = ACTIVATION;
// Serial.println("VEILLE");
// }else if(oeuvreState == ACTIVATION){
// analogWrite(PIN_LAMP, LIGHT_ACTIVATION);
// oeuvreState = VEILLE2;
// Serial.println("ACTIVATION");
// }else if(oeuvreState == VEILLE2){
// analogWrite(PIN_LAMP, LIGHT_VEILLE2);
// oeuvreState = RAZ;
// Serial.println("VEILLE2");
// }else if(oeuvreState == RAZ){
// analogWrite(PIN_LAMP, 0);
// oeuvreState = VEILLE;
// Serial.println("RAZ");
} // clickUp
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclickbuttonUp()
// EEPROM.put(0, eeprom);
Serial.println("Button up saveEEPROM.");
} // doubleclickbuttonUp
// This function will be called once, when the button1 is pressed for a long time.
void longPressStartbuttonUp()
Serial.println("Button up longPress start");
} // longPressStart1
// This function will be called often, while the button1 is pressed for a long time.
void longPressbuttonUp()
} // longPressbuttonUp
// This function will be called once, when the button1 is released after beeing pressed for a long time.
void longPressStopbuttonUp()
Serial.println("Button up longPress stop");
} // longPressStopbuttonUp
// ... and the same for button Down:
void clickButtonDown()
stepper.move(-10);
// //analogWrite(PIN_LAMP, LIGHT_VEILLE);
// changeLight(LIGHT_VEILLE)
} // clickButtonDown
* This function is called when the button is pressed.
* It saves the current state of the EEPROM to the EEPROM.
* It then prints a message to the serial monitor
void doubleclickButtonDown()
Serial.println("Button Down saveEEPROM.");
} // doubleclickButtonDown
void longPressStartButtonDown()
Serial.println("Button down longPress start");
} // longPressStartButtonDown
* Move the stepper motor 10 steps backward.
void longPressButtonDown()
stepper.move(-10);
} // longPressButtonDown
void longPressStopButtonDown()
Serial.println("Button down longPress stop");
} // longPressStopButtonDown
// slopeInit(&mySlope, maxValue, 0, 3000);
thisSlope->startTime = millis();
thisSlope->startValue = startValue;
thisSlope->stopValue = stopValue;
thisSlope->slopeDuration = slopeDuration;
thisSlope->currentValue = startValue;
// slopeUpdate(&mySlope);
* If the current value is not equal to the stop value, then the current value is calculated by
* multiplying the time elapsed by the slope duration, and then dividing that by the slope duration.
* The current value is then added to the start value
* @param thisSlope the slope object to update
* @return A boolean value.
if (thisSlope->currentValue != thisSlope->stopValue)
// if((millis() - thisSlope->startTime) <= thisSlope->slopeDuration) {
thisSlope->currentValue = ((millis() - thisSlope->startTime) * (thisSlope->stopValue - thisSlope->startValue));
thisSlope->currentValue /= thisSlope->slopeDuration;
thisSlope->currentValue += thisSlope->startValue;
return (false);
else
return (true);
// ping callback
* When the sonar sends a ping, print the distance to the object
* @param sonar The sonar object that is being used.
// Serial.print("Ping: ");
// Serial.println(sonar.GetMeasureMM());
if(sonarState != STABLE)Serial.println("Sonar stable");
sonarState = STABLE;
// timeout callback
if(sonarState != INIT_SONAR)Serial.println("Sonar INIT_SONAR");
//Serial.println("TimeOut");
* It changes the state of the current scenar.
* @param oeuvreState the state of the oeuvre (INIT, PLAY, PAUSE, STOP)
void changeScenar(enumOeuvreState oeuvreState)
currentScenar.oeuvreState = oeuvreState;
currentScenar.scenarState = INIT_SCENAR;
currentScenar.timeValue = myTime;
currentScenar.positionMotor = 0;
currentScenar.motorState=INIT;
Serial.println("changeScenar: ");
case VEILLE:
break;
case ACTIVATION:
break;
case VEILLE2:
break;
case RAZ:
break;
default:
break;
* Change the light to the value given in parameter.
* @param value The value to set the pin to.
// si la valeur est la même que l'actuelle on ne fait rien
if (value != currentPosition_light)
analogWrite(PIN_LAMP, value);
currentPosition_light = value;
#ifdef LOG_DEBUG
Serial.print("changeLight: ");
Serial.println(currentPosition_light);
#endif
* If the value is different from the current position, move the motor to the new position
* @param value the value of the input
if(value < MOTOR_REF_0)value=MOTOR_REF_0;
if(value > MOTOR_REF_MAX)value=MOTOR_REF_MAX;
if (value != currentPosition_motor)
// #ifdef WITH_MOTOR
stepper.moveTo(value);
// #endif
if(value>currentPosition_motor)currentScenar.motorState=UP;
else currentScenar.motorState=DOWN;
currentPosition_motor = value;
currentScenar.positionMotor = currentPosition_motor;
// INIT,
// OFF,
// UP,
// DOWN,
#ifdef LOG_DEBUG
Serial.print("changeMotor: ");
Serial.println(currentPosition_motor);
#endif
}else{
currentScenar.motorState=OFF;
// Vérifie si le moteur est arrivé à destination ou bien?
enumMotorState updateStateMotor(){
if (currentScenar.positionMotor == stepper.currentPosition()){
return currentScenar.motorState;
// TODO : permettre d'indiquer si la valeur est correcte ou pas?
unsigned int getSonar(){
// on retourne
return sonar.GetMeasureMM();
* If the time is greater than or equal to the delayStop, return true
* @param timeStart the time at which the timer starts
* @param delayStop The time in milliseconds that you want to delay the program.
boolean diffTime(unsigned long timeStart, unsigned long delayStop){
if (myTime - timeStart >= delayStop){
return true;
return false;
* Scenario de veille déclenché après un temps non négligeable 30 secondes
void scenarVeille()
if (currentScenar.scenarState == INIT_SCENAR)
// Serial.println("scenarVeille INIT_SCENAR");
// on accèlère le mouvement
stepper.setAcceleration(200);
changeMotor(MOTOR_POS_VEILLE);
// On remet la lumière si besoin
slopeInit(&lampSlope, currentPosition_light, LIGHT_VEILLE, DELAY_LIGHT_VEILLE);
initMeasureRAZ=getSonar();
currentScenar.scenarState=RUN;
else
//Serial.println("scenarVeille RUN");
if(!slopeUpdate(&lampSlope)){
changeLight(int(lampSlope.currentValue));
}else
//Effet clignotement
// on peut fare varier la lumière ici
int lightTmp=int(lampSlope.currentValue)==LIGHT_VEILLE?LIGHT_VEILLE_BLINK:LIGHT_VEILLE;
slopeInit(&lampSlope, currentPosition_light, lightTmp, DELAY_LIGHT_VEILLE);
if (sonarState == STABLE)
// si le sonar est coupé par qq1, on passe en Activation
// et que la position du moteur est là où on l'a demandé
if(getSonar() < 1500 && updateStateMotor() == OFF){
changeScenar(ACTIVATION);
// uint16_t mesureTmp = sonar.GetMeasureMM();
// // lumière LIGHT_VEILLE
// if (mesureTmp < initMeasureRAZ && mesureTmp > 1500 && initMeasureRAZ - mesureTmp > 100)
// // on passe en activation
// changeLight(LIGHT_ACTIVATION);
// lastMeasureSensor = mesureTmp;
// stepper.moveTo(0);
// Serial.println("oeuvreState = ACTIVATION;");
// else
// changeLight(LIGHT_VEILLE);
// position POSITION_VEILLE
* Scenario d'activation
unsigned long lastMoves=0; // dernier mouveent enregistrés que ça soit le moteur qui bouge ou le sonar
//#ifdef LOG_DEBUG
//#endif
// on allume la lumière à la valeur max
// on fait bouger selon le sonar
// Si rien pendant 30S on va en veille2
Serial.println("scenarActivation INIT_SCENAR");
// changeMotor(MOTOR_POS_VEILLE);
slopeInit(&lampSlope, currentPosition_light, LIGHT_ACTIVATION, DELAY_LIGHT_ACTIVATION);
lastMeasureSensor = getSonar();
currentScenar.scenarState = RUN;
else
//Serial.println("scenarActivation RUN");
if (!slopeUpdate(&lampSlope))
lastMoves = myTime;
//Serial.println("!slopeUpdate(&lampSlope) move");
else
// si le moteur n'est pas en déplacement : càd dire qu'il a atteint sa position
if (updateStateMotor() == OFF)
uint16_t mesureTmp = getSonar();
int diffMesure = lastMeasureSensor - mesureTmp;
// FIXME : gérer une fonction ABS
int absDiffMesure = absTmp(diffMesure);
// FIXME : régler les valeurs MIN et MAX
if (absDiffMesure > DELTA_MOVE_MIN && diffMesure < DELTA_MOVE_MAX)
changeMotor(currentScenar.positionMotor + diffMesure);
//Serial.println("lastMoves 2");
lastMoves = myTime;
Serial.print("lastMoves 2 ");
Serial.println(lastMoves);
#ifdef LOG_DEBUG
Serial.print("diffMesure > 50 < 500 : ");
Serial.println(diffMesure);
#endif
else
#ifdef LOG_DEBUG
Serial.print("diffMesure < 50 || > 500 : ");
#endif
else
// on bouge donc on met à jour le lastMoves
lastMoves = myTime;
// Serial.print("lastMoves 3 ");
// Serial.println(lastMoves);
// si pas de modif du sonar et pas d'action depuis
if(myTime-lastMoves>DELAY_GO_VEILLE2){
changeScenar(VEILLE2);
// // si le sonar est coupé, on passe en Activation
// if (getSonar() < 1500)
// changeScenar(ACTIVATION);
// on allume la lumière à la valeur veille2
// et si on bouge devant le capteur on revient
Serial.println("scenarVeille2 INIT_SCENAR");
slopeInit(&lampSlope, currentPosition_light, LIGHT_VEILLE2, DELAY_LIGHT_VEILLE2);
else
Serial.println("scenarVeille2 RUN");
}else
// int lightTmp=int(lampSlope.currentValue)===LIGHT_VEILLE?LIGHT_VEILLE_BLINK:LIGHT_VEILLE;
// slopeInit(&lampSlope, currentPosition_light, lightTmp, DELAY_LIGHT_VEILLE);
if(getSonar() < 1500){
* Scenaria RAZ fait au démarrage du bouzin
void scenarRAZ()
// Serial.print("initMeasureRAZ : ");
// Serial.println(initMeasureRAZ);
//Serial.println("scenarRAZ INIT_SCENAR");
changeLight(0);
slopeInit(&lampSlope, 0, LIGHT_RAZ, DELAY_RAZ);
// FIXME : RAZ
// On doit faire remonter jusqu'à 0;
// on force de -10
stepper.moveTo(MOTOR_REF_0);
// On attend 10 secondes
// else if (diffTime(currentScenar.timeValue,DELAY_RAZ)==TRUE) // && initMeasureRAZ > 2000)
// changeScenar(VEILLE);
else
// Serial.println("scenarRAZ RUN");
// on fait une pente pour atteindre la luminosité de VEILLE
// FIXME : il faut attendre que le sonar se stabilise
if(slopeUpdate(&lampSlope) /*&& sonarState == STABLE*/){
// on va tenter du bloquant
if(stepper.currentPosition()==MOTOR_REF_0){
Serial.print(millis());
Serial.println(" move -10");
stepper.setMaxSpeed(MAXSPEED_INIT_RAZ);
// déplacement relatif de -10
stepper.move(RETURN_TO_RAZ);
Serial.println(" before runToPosition");
// fonction bloquante
stepper.runToPosition();
Serial.println(" After runToPosition");
stepper.setCurrentPosition(MOTOR_REF_0);
initMeasureRAZ = sonar.GetMeasureMM();
// on initialise le current position
currentPosition_motor=MOTOR_REF_0;
myTime=millis();
// on a fini la pente, on y va
}else{
// if (myTime - lastTimeStep > 10000 && initMeasureRAZ > 2000)
// // initMeasureRAZ=sonar.GetMeasureMM();
// // Serial.print("initMeasureRAZ: ");
// // Serial.println(initMeasureRAZ);
// // oeuvreState = VEILLE;
// // scenarState = INIT;
// // stepper.moveTo(-200);
// // Serial.println("oeuvreState = VEILLE;");
// else
// // // on positionne tout en haut avec +10 pas
// // // après la position mettre en pause pour éviter que ça bascule
// // // initMeasureRAZ=sonar.GetMeasureMM();
// // if (currentPosition_light != 1)
// // lastTimeStep = myTime;
// // changeLight(1);
// // // if(stepper.getCurrentPosition()==0){
// // // on le remonte de 10
// // // TODO : faire remonter et stopper
// // stepper.move(0);
// // stepper.setCurrentPosition(0);
// // // stepper.moveTo(0);
// // // Serial.println("oeuvreState = RAZ;");
// // // lastTimeStep = myTime;
- FabriceD
- Compétence en photographie : Oui
Bon je vous confirme, ma femme a la COVID je ne viendrais donc pas...
Petite remarque par rapport au capteur ultrason (le 2ème) qui ne marchait pas hier: bien qu'ils aient la même référence HC-SR04, si vous regardez derrière l'électronique est, il me semble, différente. Méfiance donc.
J'ai modifié la librairie AsyncSonar (je sais c'est sale, mais dans l'urgence) pour qu'elle marche avec 2 broches, je mets les fichiers modifiés en pièce jointe... Faire un backup des originaux avant tant qu'à faire !!!
J'ai fait l'essai et chez moi ça fonctionne, à voir avec le moteur...
Pour l'appel, il suffit de modifier la ligne de déclaration comme suit:
#define PIN_SONAR_TRIG 13
#define PIN_SONAR_ECHO 12
AsyncSonar sonar(PIN_SONAR_TRIG, PIN_SONAR_ECHO, PingRecieved, TimeOut);
- Fichiers joints
- AsyncSonarLib_Modified.zip
- (3.04 Kio) Téléchargé 689 fois
- FabriceD
Pour les boutons-poussoirs il sont déjà déclarés dans le code sur les entrées A0 & A1 avec les résistances de pull-up internes activées: donc rien à faire
Il suffit juste de relier le GND aux boutons d'un côté, et d'aller au broches de l'arduino respectives de l'autre côté.
- FabriceD
A chaud, faire cet essai qui est très rapide et ne demande pas de recâbler:
Dans la librairie AsyncSonar originale dans le fichier AsyncSonarLib.cpp modifier la ligne 118 en
delayMicroseconds(100); (voire 200)
au lieu de
delayMicroseconds(10);
car l'impulsion de déclenchement du sonar est très très courte, alors avec des fils longs et du bruit c'est pas idéal
au lieu de
- FabriceD
Je viens de regarder le code. La librairie est aussi prévue pour fonctionner avec notre câblage actuel, il suffit de mettre pin_trig & pin_echo à la même valeur (A5).ronan a écrit : ↑mer. 30 mars 2022 09:36Essai de la bibliothèque ultrasonic ...
A suivre
c'est ce qu'on a testé hier sans succès, je reteste cet après midiFabriceD a écrit : ↑mer. 30 mars 2022 13:46Je viens de regarder le code. La librairie est aussi prévue pour fonctionner avec notre câblage actuel, il suffit de mettre pin_trig & pin_echo à la même valeur (A5).ronan a écrit : ↑mer. 30 mars 2022 09:36Essai de la bibliothèque ultrasonic ...
A suivre
- FabriceD
J'en suis à ça:
Je pense qu'on peut difficilement faire plus représentatif (et dégueulasse). Et ça marche...
http://fabrice.dondeyne.free.fr/bricola ... 151116.jpg
Je me disais, vu qu'on a cramé un arduino et un driver de moteur, si on avait cramé le capteur ultrason et qu'il marche mal ?
Modifié en dernier par FabriceD le mer. 30 mars 2022 15:38, modifié 1 fois.
je teste avec deux autres, j'ai des soucis avec les lib...
on met au point avec les boutons UP et DOWN
