Exposition Flop Avril 2022
ronan
Re: Exposition Flop Avril 2022
Message par ronan »
Essai de la bibliothèque ultrasonic ...
A suivre
https://github.com/ErickSimoes/Ultrason ... Simple.ino
ronan
Message par ronan »
Code source mis à jour le 29/03/2022
Code : Tout sélectionner
#include <AccelStepper.h>
#include <AsyncSonarLib.h>
#include <OneButton.h>
#define DEBUG 1
#define WITH_MOTOR 1
// level de log debug
#define LOG_DEBUG 1
#define LIGHT_VEILLE 2
#define LIGHT_VEILLE_BLINK 150
#define LIGHT_ACTIVATION 255
#define LIGHT_VEILLE2 80
#define LIGHT_RAZ 80
#define MOTOR_POS_VEILLE 3000//1200
#define MOTOR_REF_0 0
#define MOTOR_REF_MAX 3200
#define RETURN_TO_RAZ -3500
#define DELAY_RAZ 20000
#define DELAY_LIGHT_VEILLE 1500
#define DELAY_LIGHT_VEILLE2 5000
#define DELAY_LIGHT_ACTIVATION 5000
#define DELAY_GO_VEILLE2 20000
#define DELTA_MOVE_MIN 50
#define DELTA_MOVE_MAX 300
#define PIN_LAMP 11
#define PIN_STEP 8
#define PIN_DIR 4
#define PIN_UP A0
#define PIN_DOWN A1
#define PIN_SONAR A5
#define BANDGAP 10
// SPEED 500 ne fonctionne pas
#define MAXSPEED_WORKMDODE 400
#define MAXSPEED_TUNINGMODE 100
#define MOTOR_ACCELERATION 200
#define MAXSPEED_INIT_RAZ 200
struct slope
    uint32_t startTime;
    uint8_t startValue;     // (0-255)
    uint8_t stopValue;      // (255-0)
    uint16_t slopeDuration; // (1-65535)
    int32_t currentValue;
struct variablesToSave
    uint16_t stepToFloor;
    byte dummy_1;     // just for note
    int dummy_2 = -8; // just for note
enum enumMotorState
    INIT,
    OFF,
    UP,
    DOWN,
enumMotorState motorState, previousMotorState;
boolean onEntryState;
int8_t sens;
slope lampSlope;
#ifdef DEBUG
uint32_t u32_cpu_load;
#endif
uint16_t toto, oldtoto, initMeasureRAZ, lastMeasureSensor;
unsigned long myTime, lastTimeStep;
variablesToSave eeprom;
enum enumOeuvreState
    VEILLE = 0,
    ACTIVATION, // dès qu'on met la main
    VEILLE2,
    RAZ // on recherche la position 0
enumOeuvreState oeuvreState, previousOeuvreState;
enum enumScenarState
    INIT_SCENAR,
    RUN
enumScenarState scenarState;
enum enumSONARState
    INIT_SONAR,
    STABLE
struct scenar
    enumOeuvreState oeuvreState;
    unsigned long timeValue; // valeur de temps utilisable pour contrôler ce que l'on veut
    long positionMotor; // position du moteur demandée, on ne change pas tant qu'on n'y est pas
    enumMotorState motorState;
scenar currentScenar;
enumSONARState sonarState;
unsigned long lastTSMesure=0;
/***** Prototype definition of code *****/
void slopeInit(slope *thisSlope, uint16_t startValue, uint16_t stopValue, uint16_t slopeDuration);
boolean slopeUpdate(slope *thisSlope);
void PingRecieved(AsyncSonar &sonar);
void TimeOut(AsyncSonar &sonar);
void changeLight(int value);
void changeMotor(long value);
void scenarVeille();
void scenarActivation();
void scenarVeille2();
void scenarRAZ();
AccelStepper stepper(AccelStepper::DRIVER, PIN_STEP, PIN_DIR);
// AccelStepper stepper(AccelStepper::FULL4WIRE, 2, 3, 4, 5);
AsyncSonar sonar(PIN_SONAR, PingRecieved, TimeOut);
OneButton buttonUp(PIN_UP, true, true);     // active low, pull-up
OneButton buttonDown(PIN_DOWN, true, true); // active low, pull-up
int currentPosition_light;
long currentPosition_motor;
unsigned int absTmp(int v){
    return (v>=0)?v:(-1*v);
void setup()
#ifdef DEBUG
    Serial.begin(250000); // for debug purposes
#endif
    // initialize lamp
    pinMode(PIN_LAMP, OUTPUT);
    analogWrite(PIN_LAMP, 0);
    // initialize stepper;
    stepper.setMaxSpeed(MAXSPEED_WORKMDODE);
    stepper.setAcceleration(MOTOR_ACCELERATION);
    // initialize sonar
    sonar.Start(500);
    sonarState = INIT_SONAR;
    // initialize motor state machine
    motorState = INIT;
    previousMotorState = ~INIT;
    myTime = millis();
    //Serial.println("Before Delay setup");
    //delay(10000);
    //Serial.println("After Delay setup");
    changeScenar(RAZ);
void loop()
    myTime = millis();
    switch (currentScenar.oeuvreState)
        case VEILLE:
            scenarVeille();
            break;
        case ACTIVATION:
            scenarActivation();
            break;
        case VEILLE2:
            scenarVeille2();
            break;
        case RAZ:
            scenarRAZ();
            break;
        default:
            break;
    sonar.Update(&sonar);
    stepper.run();
   // delay(10);
// ----- button Up callback functions
// This function will be called when the button1 was pressed 1 time (and no 2. button press followed).
void clickbuttonUp()
    // stepper.move(10);
    // analogWrite(PIN_LAMP, LIGHT_VEILLE);
    //    if(oeuvreState == VEILLE){
    //      oeuvreState = ACTIVATION;
    //      Serial.println("VEILLE");
    //    }else if(oeuvreState == ACTIVATION){
    //      analogWrite(PIN_LAMP, LIGHT_ACTIVATION);
    //      oeuvreState = VEILLE2;
    //      Serial.println("ACTIVATION");
    //    }else if(oeuvreState == VEILLE2){
    //      analogWrite(PIN_LAMP, LIGHT_VEILLE2);
    //      oeuvreState = RAZ;
    //      Serial.println("VEILLE2");
    //    }else if(oeuvreState == RAZ){
    //      analogWrite(PIN_LAMP, 0);
    //      oeuvreState = VEILLE;
    //      Serial.println("RAZ");
} // clickUp
// This function will be called when the button1 was pressed 2 times in a short timeframe.
void doubleclickbuttonUp()
    // EEPROM.put(0, eeprom);
    Serial.println("Button up saveEEPROM.");
} // doubleclickbuttonUp
// This function will be called once, when the button1 is pressed for a long time.
void longPressStartbuttonUp()
    Serial.println("Button up longPress start");
} // longPressStart1
// This function will be called often, while the button1 is pressed for a long time.
void longPressbuttonUp()
} // longPressbuttonUp
// This function will be called once, when the button1 is released after beeing pressed for a long time.
void longPressStopbuttonUp()
    Serial.println("Button up longPress stop");
} // longPressStopbuttonUp
// ... and the same for button Down:
void clickButtonDown()
    stepper.move(-10);
    //      //analogWrite(PIN_LAMP, LIGHT_VEILLE);
    //      changeLight(LIGHT_VEILLE)
} // clickButtonDown
 * This function is called when the button is pressed.
 * It saves the current state of the EEPROM to the EEPROM.
 * It then prints a message to the serial monitor
void doubleclickButtonDown()
    Serial.println("Button Down saveEEPROM.");
} // doubleclickButtonDown
void longPressStartButtonDown()
    Serial.println("Button down longPress start");
} // longPressStartButtonDown
 * Move the stepper motor 10 steps backward.
void longPressButtonDown()
    stepper.move(-10);
} // longPressButtonDown
void longPressStopButtonDown()
    Serial.println("Button down longPress stop");
} // longPressStopButtonDown
// slopeInit(&mySlope, maxValue, 0, 3000);
    thisSlope->startTime = millis();
    thisSlope->startValue = startValue;
    thisSlope->stopValue = stopValue;
    thisSlope->slopeDuration = slopeDuration;
    thisSlope->currentValue = startValue;
// slopeUpdate(&mySlope);
 * If the current value is not equal to the stop value, then the current value is calculated by
 * multiplying the time elapsed by the slope duration, and then dividing that by the slope duration.
 * The current value is then added to the start value
 * @param thisSlope the slope object to update
 * @return A boolean value.
    if (thisSlope->currentValue != thisSlope->stopValue)
        // if((millis() - thisSlope->startTime) <= thisSlope->slopeDuration) {
        thisSlope->currentValue = ((millis() - thisSlope->startTime) * (thisSlope->stopValue - thisSlope->startValue));
        thisSlope->currentValue /= thisSlope->slopeDuration;
        thisSlope->currentValue += thisSlope->startValue;
        return (false);
    else
        return (true);
// ping callback
 * When the sonar sends a ping, print the distance to the object
 * @param sonar The sonar object that is being used.
    // Serial.print("Ping: ");
    // Serial.println(sonar.GetMeasureMM());
    if(sonarState != STABLE)Serial.println("Sonar stable");
    sonarState = STABLE;
// timeout callback
    if(sonarState != INIT_SONAR)Serial.println("Sonar INIT_SONAR");
    //Serial.println("TimeOut");
 * It changes the state of the current scenar.
 * @param oeuvreState the state of the oeuvre (INIT, PLAY, PAUSE, STOP)
void changeScenar(enumOeuvreState oeuvreState)
    currentScenar.oeuvreState = oeuvreState;
    currentScenar.scenarState = INIT_SCENAR;
    currentScenar.timeValue = myTime;
    currentScenar.positionMotor = 0;
    currentScenar.motorState=INIT;
    Serial.println("changeScenar: ");
    case VEILLE:
        break;
    case ACTIVATION:
        break;
    case VEILLE2:
        break;
    case RAZ:
        break;
    default:
        break;
 * Change the light to the value given in parameter.
 * @param value The value to set the pin to.
    // si la valeur est la même que l'actuelle on ne fait rien
    if (value != currentPosition_light)
        analogWrite(PIN_LAMP, value);
        currentPosition_light = value;
        #ifdef LOG_DEBUG
            Serial.print("changeLight: ");
            Serial.println(currentPosition_light);
        #endif
 * If the value is different from the current position, move the motor to the new position
 * @param value the value of the input
    if(value < MOTOR_REF_0)value=MOTOR_REF_0;
    if(value > MOTOR_REF_MAX)value=MOTOR_REF_MAX;
    if (value != currentPosition_motor)
        // #ifdef WITH_MOTOR
            stepper.moveTo(value);
        // #endif
        if(value>currentPosition_motor)currentScenar.motorState=UP;
        else currentScenar.motorState=DOWN;
        currentPosition_motor = value;
        currentScenar.positionMotor = currentPosition_motor;
    // INIT,
    // OFF,
    // UP,
    // DOWN,
        #ifdef LOG_DEBUG
            Serial.print("changeMotor: ");
            Serial.println(currentPosition_motor);
        #endif
    }else{
        currentScenar.motorState=OFF;
// Vérifie si le moteur est arrivé à destination ou bien?
enumMotorState updateStateMotor(){
    if (currentScenar.positionMotor == stepper.currentPosition()){
    return currentScenar.motorState;
// TODO : permettre d'indiquer si la valeur est correcte ou pas?
unsigned int getSonar(){
    // on retourne
    return sonar.GetMeasureMM();
 * If the time is greater than or equal to the delayStop, return true
 * @param timeStart the time at which the timer starts
 * @param delayStop The time in milliseconds that you want to delay the program.
boolean diffTime(unsigned long timeStart, unsigned long delayStop){
    if (myTime - timeStart >= delayStop){
        return true;
    return false;
 * Scenario de veille déclenché après un temps non négligeable 30 secondes
void scenarVeille()
    if (currentScenar.scenarState == INIT_SCENAR)
       // Serial.println("scenarVeille INIT_SCENAR");
        // on accèlère le mouvement
        stepper.setAcceleration(200);
        changeMotor(MOTOR_POS_VEILLE);
        // On remet la lumière si besoin
        slopeInit(&lampSlope, currentPosition_light, LIGHT_VEILLE, DELAY_LIGHT_VEILLE);
        initMeasureRAZ=getSonar();
        currentScenar.scenarState=RUN;
    else
        //Serial.println("scenarVeille RUN");
        if(!slopeUpdate(&lampSlope)){
            changeLight(int(lampSlope.currentValue));
        }else
            //Effet clignotement
            // on peut fare varier la lumière ici
            int lightTmp=int(lampSlope.currentValue)==LIGHT_VEILLE?LIGHT_VEILLE_BLINK:LIGHT_VEILLE;
            slopeInit(&lampSlope, currentPosition_light, lightTmp, DELAY_LIGHT_VEILLE);
        if (sonarState == STABLE)
            // si le sonar est coupé par qq1, on passe en Activation
            // et que la position du moteur est là où on l'a demandé
            if(getSonar() < 1500 && updateStateMotor() == OFF){
                changeScenar(ACTIVATION);
    // uint16_t mesureTmp = sonar.GetMeasureMM();
    // // lumière LIGHT_VEILLE
    // if (mesureTmp < initMeasureRAZ && mesureTmp > 1500 && initMeasureRAZ - mesureTmp > 100)
    //     // on passe en activation
    //     changeLight(LIGHT_ACTIVATION);
    //     lastMeasureSensor = mesureTmp;
    //     stepper.moveTo(0);
    //     Serial.println("oeuvreState = ACTIVATION;");
    // else
    //     changeLight(LIGHT_VEILLE);
    // position POSITION_VEILLE
 * Scenario d'activation
unsigned long lastMoves=0; // dernier mouveent enregistrés que ça soit le moteur qui bouge ou le sonar
    //#ifdef LOG_DEBUG
    //#endif
    // on allume la lumière à la valeur max
    // on fait bouger selon le sonar
    // Si rien pendant 30S on va en veille2
        Serial.println("scenarActivation INIT_SCENAR");
        // changeMotor(MOTOR_POS_VEILLE);
        slopeInit(&lampSlope, currentPosition_light, LIGHT_ACTIVATION, DELAY_LIGHT_ACTIVATION);
        lastMeasureSensor = getSonar();
        currentScenar.scenarState = RUN;
    else
        //Serial.println("scenarActivation RUN");
        if (!slopeUpdate(&lampSlope))
            lastMoves = myTime;
            //Serial.println("!slopeUpdate(&lampSlope) move");
        else
            // si le moteur n'est pas en déplacement : càd dire qu'il a atteint sa position
            if (updateStateMotor() == OFF)
                    uint16_t mesureTmp = getSonar();
                    int diffMesure = lastMeasureSensor - mesureTmp;
                    // FIXME : gérer une fonction ABS
                    int absDiffMesure = absTmp(diffMesure);
                    // FIXME : régler les valeurs MIN et MAX
                    if (absDiffMesure > DELTA_MOVE_MIN && diffMesure < DELTA_MOVE_MAX)
                        changeMotor(currentScenar.positionMotor + diffMesure);
                        //Serial.println("lastMoves 2");
                        lastMoves = myTime;
                        Serial.print("lastMoves 2 ");
                        Serial.println(lastMoves);
#ifdef LOG_DEBUG
                        Serial.print("diffMesure > 50 < 500 : ");
                        Serial.println(diffMesure);
#endif
                    else
#ifdef LOG_DEBUG
                        Serial.print("diffMesure < 50 || > 500 : ");
#endif
            else
                // on bouge donc on met à jour le lastMoves
                lastMoves = myTime;
                // Serial.print("lastMoves 3 ");
                // Serial.println(lastMoves);
        // si pas de modif du sonar et pas d'action depuis
        if(myTime-lastMoves>DELAY_GO_VEILLE2){
            changeScenar(VEILLE2);
        // // si le sonar est coupé, on passe en Activation
        // if (getSonar() < 1500)
        //     changeScenar(ACTIVATION);
    // on allume la lumière à la valeur veille2
    // et si on bouge devant le capteur on revient
        Serial.println("scenarVeille2 INIT_SCENAR");
        slopeInit(&lampSlope, currentPosition_light, LIGHT_VEILLE2, DELAY_LIGHT_VEILLE2);
    else
        Serial.println("scenarVeille2 RUN");
        }else
            // int lightTmp=int(lampSlope.currentValue)===LIGHT_VEILLE?LIGHT_VEILLE_BLINK:LIGHT_VEILLE;
            // slopeInit(&lampSlope, currentPosition_light, lightTmp, DELAY_LIGHT_VEILLE);
        if(getSonar() < 1500){
 * Scenaria RAZ fait au démarrage du bouzin
void scenarRAZ()
    // Serial.print("initMeasureRAZ : ");
    // Serial.println(initMeasureRAZ);
        //Serial.println("scenarRAZ INIT_SCENAR");
        changeLight(0);
        slopeInit(&lampSlope, 0, LIGHT_RAZ, DELAY_RAZ);
        // FIXME : RAZ
        // On doit faire remonter jusqu'à 0;
        // on force de -10
        stepper.moveTo(MOTOR_REF_0);
    // On attend 10 secondes
    // else if (diffTime(currentScenar.timeValue,DELAY_RAZ)==TRUE) // && initMeasureRAZ > 2000)
    //     changeScenar(VEILLE);
    else
        // Serial.println("scenarRAZ RUN");
        // on fait une pente pour atteindre la luminosité de VEILLE
        // FIXME  : il faut attendre que le sonar se stabilise
        if(slopeUpdate(&lampSlope) /*&& sonarState == STABLE*/){
            // on va tenter du bloquant
            if(stepper.currentPosition()==MOTOR_REF_0){
                Serial.print(millis());
                Serial.println(" move -10");
                stepper.setMaxSpeed(MAXSPEED_INIT_RAZ);
                // déplacement relatif de -10
                stepper.move(RETURN_TO_RAZ);
                Serial.println(" before runToPosition");
                // fonction bloquante
                stepper.runToPosition();
                Serial.println(" After runToPosition");
                stepper.setCurrentPosition(MOTOR_REF_0);
                initMeasureRAZ = sonar.GetMeasureMM();
                // on initialise le current position
                currentPosition_motor=MOTOR_REF_0;
                myTime=millis();
                // on a fini la pente, on y va
        }else{
    // if (myTime - lastTimeStep > 10000 && initMeasureRAZ > 2000)
    //     // initMeasureRAZ=sonar.GetMeasureMM();
    //     //  Serial.print("initMeasureRAZ: ");
    //     //  Serial.println(initMeasureRAZ);
    //     //  oeuvreState = VEILLE;
    //     //  scenarState = INIT;
    //     //  stepper.moveTo(-200);
    //     //  Serial.println("oeuvreState = VEILLE;");
    // else
    //     // // on positionne tout en haut avec +10 pas
    //     // // après la position mettre en pause pour éviter que ça bascule
    //     // // initMeasureRAZ=sonar.GetMeasureMM();
    //     // if (currentPosition_light != 1)
    //     //     lastTimeStep = myTime;
    //     // changeLight(1);
    //     // // if(stepper.getCurrentPosition()==0){
    //     // //  on le remonte de 10
    //     // // TODO : faire remonter et stopper
    //     // stepper.move(0);
    //     // stepper.setCurrentPosition(0);
    //     // // stepper.moveTo(0);
    //     // // Serial.println("oeuvreState = RAZ;");
    //     // // lastTimeStep = myTime;
Bon je vous confirme, ma femme a la COVID je ne viendrais donc pas... :evil:
Petite remarque par rapport au capteur ultrason (le 2ème) qui ne marchait pas hier: bien qu'ils aient la même référence HC-SR04, si vous regardez derrière l'électronique est, il me semble, différente. Méfiance donc.
J'ai modifié la librairie AsyncSonar (je sais c'est sale, mais dans l'urgence) pour qu'elle marche avec 2 broches, je mets les fichiers modifiés en pièce jointe... Faire un backup des originaux avant tant qu'à faire !!!
J'ai fait l'essai et chez moi ça fonctionne, à voir avec le moteur...
Pour l'appel, il suffit de modifier la ligne de déclaration comme suit:
#define PIN_SONAR_TRIG 13
#define PIN_SONAR_ECHO 12
AsyncSonar sonar(PIN_SONAR_TRIG, PIN_SONAR_ECHO, PingRecieved, TimeOut);
Fichiers joints
AsyncSonarLib_Modified.zip
(3.04 Kio) Téléchargé 359 fois
Pour les boutons-poussoirs il sont déjà déclarés dans le code sur les entrées A0 & A1 avec les résistances de pull-up internes activées: donc rien à faire
Il suffit juste de relier le GND aux boutons d'un côté, et d'aller au broches de l'arduino respectives de l'autre côté.
A chaud, faire cet essai qui est très rapide et ne demande pas de recâbler:
Dans la librairie AsyncSonar originale dans le fichier AsyncSonarLib.cpp modifier la ligne 118 en
delayMicroseconds(100); (voire 200)
au lieu de
delayMicroseconds(10);
car l'impulsion de déclenchement du sonar est très très courte, alors avec des fils longs et du bruit c'est pas idéal
ronan a écrit :
mer. 30 mars 2022 09:36
A suivre
Je viens de regarder le code. La librairie est aussi prévue pour fonctionner avec notre câblage actuel, il suffit de mettre pin_trig & pin_echo à la même valeur (A5).
ronan
Message par ronan »
FabriceD a écrit :
mer. 30 mars 2022 13:46
A suivre
c'est ce qu'on a testé hier sans succès, je reteste cet après midi
J'en suis à ça:
Je pense qu'on peut difficilement faire plus représentatif (et dégueulasse). Et ça marche... :?
http://fabrice.dondeyne.free.fr/bricola ... 151116.jpg
Je me disais, vu qu'on a cramé un arduino et un driver de moteur, si on avait cramé le capteur ultrason et qu'il marche mal ?
Modifié en dernier par FabriceD le mer. 30 mars 2022 15:38, modifié 1 fois.
ronan
Message par ronan »
je teste avec deux autres, j'ai des soucis avec les lib...
ronan
Message par ronan »
on met au point avec les boutons UP et DOWN
